TwinTurbo.NET: Nissan 300ZX forum - I would check the wiring from the harness to the ECU. (n/m)
Draker (Eugene, OR)
on August 22, 2011 at 11:25 AM
constant knock
posted by idslave
on August 22, 2011 at 10:46 AM
constant knock
idslave
10:46:09 08/22/11
Re: constant knock
idslave
10:49:48 08/22/11
I would check the wiring from the harness to the ECU. (n/m) -
Draker (Eugene, OR)
11:25:29 08/22/11
What'd be the best way to do that?
idslave
13:56:33 08/22/11
I would pull the ECU connector
Draker (Eugene, OR)
18:38:58 08/22/11
Are you sure your using a 1 mega ohm resistor? and
supermario680
22:20:24 08/24/11
yes (n/m)
idslave
15:23:46 08/28/11
Re: constant knock
AsaHerring
23:10:50 08/25/11
if you are going to get your ECU chipped
idslave
15:25:49 08/28/11
Re: if you are going to get your ECU chipped
AsaHerring
17:29:50 08/30/11
